It is currently Mon Mar 23, 2026 4:45 pm
Reply to topic  [ 3 posts ]
 23hp longtail
Post 23hp longtail
Hello,
Was hoping to get some feedback about a longtail issue I'm having...have a 2003 23 HP GD longtail. Just replaced the solenoid, ignition, and wiring...it would start up fine, but now, it won't start up (right after I put new wiring harness in). When I do the manual start (from pull cord), it starts up fine...but an issue I'm having is that when I move the key to the "off" position on the ignition switch it does not shut off like it used to...thoughts?
Thu May 19, 2011 8:35 pm
Post Re: 23hp longtail
could it be the ignition switch? im horrible when it comes to electronics but that seems like something that wouldnt have been replaced with your harness. idk.. just a guess...
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Fri May 20, 2011 9:50 pm
Found out it was the diode wiring on the inside..replaced it and everything works fine...kind've crazy...thanks for the input!
Sat May 21, 2011 11:00 am
