| LT or SD? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=19008 |
| Author: | Bigbuckfever [ Fri Jun 03, 2011 1:09 pm ] |
| Post subject: | LT or SD? |
I'm starting to look for my first dedicated mud motor boat... The biggest dilemma that I've come up with now is that I was set on a SD but now I'm second guessing that. I hunt mostly Horicon Marsh in WI where there are some longer runs where I know a SD will outperform. On the other hand everyt hing is a floating cattail bog and I am now wondering if the longtail may be better because of its ability to get through that crap. I may hunt the mississippi river occasionally as well, but not often. My initial thought on a setup was a 1856 or 2056 with a 36 prodrive but now I'm wondering if a 35 longtail might be the best option. This rig will double as a bowfishing rig as well. Thanks. |
| Author: | wm [ Fri Jun 03, 2011 3:05 pm ] |
| Post subject: | Re: LT or SD? |
looks like you would be having the same problem as i am surface drive or longtail, 27 or 35 |
| Author: | Woodiebuster [ Fri Jun 03, 2011 3:11 pm ] |
The only place a longtail is better is a shallow hard bottom, logs and stumps, and places where you cant get above idle in many places. The balanced design of a longtail makes it ride up ontop of thick grass and vegitation and you have to pull up hard on the tiller to keep it under. The Pro-Drive is very weighted back and the motor is easier to keep down in the thick stuff, coupled with speed and bowfishing, a sd would be my only choice. |
