sftull
Joined: Tue Mar 08, 2011 1:33 pm Posts: 601 Location: Rock Hill, SC
 6.5lt on 1648??
I have to travel a few miles of big water to get back into the area's I hunt. The last 1/2 mile or so of water is usually 2' - 4' deep with sand and soft mud bottoms. My 1648 boat with two people, all of the necessary gear and a 40hp outboard on the back, will float back there no problem but getting back there using my trolling motor takes forever. I was planning on hanging my 6.5lt on the back along with the 40 and when the water gets to shallow for the outboard, tilt it up then swing the small lt into action. Does anyone see any problem with this idea?
_________________ 1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
| Tue Jun 21, 2011 8:09 am |
lftdjeep426
Joined: Mon Dec 13, 2010 2:15 pm Posts: 37 Location: Ft. Pierce, FL
 Re: 6.5lt on 1648??
I think its a great idea.....
More importantly,
I have a 1648 and was wondering about a 40hp. How does it run on it? Did you do any extra bracing on the transom? Got any pics of it hanging off the back of the boat? Any idea how much that 40hp weighs?
_________________ 1648 Lundau W/ MudBuddy 23hp LT(Work in Progress)
| Tue Jun 21, 2011 9:59 am |
Woodiebuster
 Re: 6.5lt on 1648??
If it's two feet deep with a unvegitated bottom, you need a good jackplate and a set of balls.
Seriously, a 6.5 won't be much better than a trolling motor and if it gets so shallow the hull starts to touch bottom the 6.5 don't have the umph to push all that.
| Tue Jun 21, 2011 10:08 am |
sftull
 Re: 6.5lt on 1648??
The jack plate and balls sounds good in theory but the problem is....they water is pretty narrow, so I can't go flying in there and take a chance of running over another hunter at 4 in the morning. I'm not looking for speed, just propulsion and guess if we get stuck, we'll get out and push.
New GT Rig
| Tue Jun 21, 2011 11:14 am |
Woodiebuster
 Re: 6.5lt on 1648??
Surely you can idle back there if the motor is raised up, is it a canal or are there high spots?
| Tue Jun 21, 2011 11:19 am |
sftull
 Re: 6.5lt on 1648??
I put the boat in a lake, run the outboard about half way into a cove then the water gets shallow. The cove shallows up to about 2 feet but then it turns into a creek which narrows up and deepens up alittle. Then it widens out and gets shallow again and it does this for about 1/4 of a mile. So I would need to raise and lower the outboard plus I don't want to take a chance of sucking up some trash into the water pump and frying the engine. I would love to have a mud rig but can't justify the cost and there aren't that many places up here where I could really use one.
New GT Rig
| Tue Jun 21, 2011 1:46 pm |
Powerstroke9773
Joined: Tue Apr 05, 2011 8:01 pm Posts: 164 Location: Nixonton, North Carolina
 Re: 6.5lt on 1648??
where ya located at sfthull ?
_________________ 17Foot Aquasport 85 Evinrude 20GDLT Looking for a Hull
| Tue Jun 21, 2011 8:05 pm |
sftull
 Re: 6.5lt on 1648??
SC
New GT Rig
| Wed Jun 22, 2011 6:24 am |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
 Re: 6.5lt on 1648??
get a pirogue
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
| Wed Jun 22, 2011 4:44 pm |
wm
Joined: Sat Feb 19, 2011 11:48 pm Posts: 782 Location: Eau Claire Wi
 Re: 6.5lt on 1648??
just run it and see how it is
_________________ 1648 alumacraft with a 35 backwaterinc
| Wed Jun 22, 2011 6:30 pm |
sftull
 Re: 6.5lt on 1648??
An update on this old post. I ran the lt and it moved the boat through some shallow water, but not very fast at all. I think my trolling motor will move it faster. I has my wife, two batteries, trolling motor, fuel, fishing gear and a 40hp hanging off the back so needless to say, its a heavy rig for the little lt. Has anyone ever put a small lt on a pirogue?
New GT Rig
| Thu Jul 28, 2011 8:38 am |
Woodiebuster
 Re: 6.5lt on 1648??
| Thu Jul 28, 2011 11:11 am |
austinabear
Joined: Tue Mar 15, 2011 11:15 pm Posts: 238 Location: Port Neches, SETX
 Re: 6.5lt on 1648??
Just run that 40 horse and don't let off, you oughhta make it
| Tue Aug 16, 2011 11:30 am |
