It is currently Mon Apr 06, 2026 8:13 am
Reply to topic  [ 12 posts ]
 24 hp BTLT speed prob
Post 24 hp BTLT speed prob
I just bought a 24 hp BTLT, and it is on a 1648 legend craft with floors. I have 4 batteries, one cooler, 2 people (190 & 220), 10 gallons of gas and my top speed I can hit is 13-14. Does this seem way to slow? Also It is a tall transom boat, and I know that the angle of the shaft entering the water may have something to do with it. My prop is also knifed edged, so will a new prop give me any more speed? Any help is great, thx.
1648 legend craft chased by a 24hp BTLT
Tue Aug 16, 2011 9:47 pm
Post Re: 24 hp BTLT speed prob
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Tue Aug 16, 2011 9:54 pm
Cut the transom down, get a new prop, pour 4 gallons of gas on ant beds in the yard, leave 2 batteries in the shed, give the plywood floors to a hobo, and find skinnier friends.
You may be able to get 18/19
Tue Aug 16, 2011 10:08 pm
Can't cut transom, floors are welded in, I have to have 4 batteries
Tue Aug 16, 2011 10:22 pm
Why to the transom and batteries?
Tue Aug 16, 2011 10:25 pm
Cause I like being able to stop on a dime and not have water come in the back of the boat and she is brand new almost. 2 for 24volt trolling motor, one to start motor, one to run all lights
Wed Aug 17, 2011 5:55 am
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Wed Aug 17, 2011 6:05 am
If you need all of that then swap props and get use to that speeds cuz that's gona be it
Wed Aug 17, 2011 9:28 am
what kind of lights you running to need a seperate battery?? i would at least use the same battery for engine and lights, that engine battery should allways have a full charge (if the engine has a charding system)
Thu Aug 18, 2011 4:50 am
Huh ok, not sure if the engine has a charging system I'll have to look into that
Thu Aug 18, 2011 7:46 pm
Yes, it has a small charging system.
Since there are no electrical componets (clutches, trim, ect.) for the battery to run, the only time the motor draws battery is when you start it.
The rest of the time you are charging the battery, it won't keep up with much more than nav. Lights and a spotlight though.
Thu Aug 18, 2011 7:54 pm
24 hp huh maybe hondagx670 motor if so it has a 20 amp charging curcuit !
Don't need a trolling motor to kill ducks dump that shit long tails don't care for alot of weight
If you HAVE to keep the extra stuff try distribute more weight up front
Thu Aug 18, 2011 8:01 pm
