| 23hp MBLT 9x5 on 1648-15mph?!? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=20988 |
| Author: | lftdjeep426 [ Sat Aug 13, 2011 8:47 pm ] |
| Post subject: | 23hp MBLT 9x5 on 1648-15mph?!? |
Just got it hooked up and with me, two batteries, full wood front deck, 5gal of gas, trolling motor and me (190 lbs) got 15mph. Is this good? It didn't sound like the motor really revved up like I thought it should compared to my old 13hp MBLT. Your thoughts? |
| Author: | Woodiebuster [ Sat Aug 13, 2011 9:20 pm ] |
| Post subject: | Re: 23hp MBLT 9x5 on 1648-15mph?!? |
Is your boat beat up on the bottom? Prop worn? |
| Author: | cb5331 [ Sat Aug 13, 2011 9:25 pm ] |
Do you have a tach? If not, get one! |
| Author: | lftdjeep426 [ Sat Aug 20, 2011 12:26 pm ] |
Prop is a fairly new MB 9x5, boat is smooth with frog spit (same as steelflex) coating on bottom and smooth. Motor turns 2990rpm's. Throttle is wide open and the cable is tight and it pulls the throttle flap to lock..... Drive shaft isn't bound up.... Got a good bit of weight in the boat but with that prop, it should rev out. |
| Author: | acs7671 [ Mon Aug 22, 2011 7:53 pm ] |
I'm no expert, but that sounds like a reasonable speed for that setup. |
| Author: | QuackStacker5253 [ Wed Aug 24, 2011 8:20 pm ] |
I agree that doesnt sound like to bad of a speed depending on how heavy your boat is... Ive got the same motor and with a couple guys in my boat we get around 15 |
| Author: | SuperDave4x4 [ Fri Aug 26, 2011 6:44 am ] |
| Author: | Snowbird [ Fri Aug 26, 2011 1:57 pm ] |
