taco1219
 24 hp BTLT speed prob
I just bought a 24 hp BTLT, and it is on a 1648 legend craft with floors. I have 4 batteries, one cooler, 2 people (190 & 220), 10 gallons of gas and my top speed I can hit is 13-14. Does this seem way to slow? Also It is a tall transom boat, and I know that the angle of the shaft entering the water may have something to do with it. My prop is also knifed edged, so will a new prop give me any more speed? Any help is great, thx.
_________________ 1648 legend craft chased by a 24hp BTLT
| Tue Aug 16, 2011 9:47 pm |
b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
 Re: 24 hp BTLT speed prob
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
| Tue Aug 16, 2011 9:54 pm |
Woodiebuster
Cut the transom down, get a new prop, pour 4 gallons of gas on ant beds in the yard, leave 2 batteries in the shed, give the plywood floors to a hobo, and find skinnier friends.
You may be able to get 18/19
| Tue Aug 16, 2011 10:08 pm |
taco1219
Can't cut transom, floors are welded in, I have to have 4 batteries
| Tue Aug 16, 2011 10:22 pm |
Woodiebuster
Why to the transom and batteries?
| Tue Aug 16, 2011 10:25 pm |
taco1219
Cause I like being able to stop on a dime and not have water come in the back of the boat and she is brand new almost. 2 for 24volt trolling motor, one to start motor, one to run all lights
| Wed Aug 17, 2011 5:55 am |
kibb
| Wed Aug 17, 2011 6:05 am |
SCmudder7071
If you need all of that then swap props and get use to that speeds cuz that's gona be it
_________________ 1754 Extreme/LAProp Stage 2 GTR
| Wed Aug 17, 2011 9:28 am |
FISHnBEER
what kind of lights you running to need a seperate battery?? i would at least use the same battery for engine and lights, that engine battery should allways have a full charge (if the engine has a charding system)
| Thu Aug 18, 2011 4:50 am |
taco1219
Huh ok, not sure if the engine has a charging system I'll have to look into that
| Thu Aug 18, 2011 7:46 pm |
Woodiebuster
Yes, it has a small charging system.
Since there are no electrical componets (clutches, trim, ect.) for the battery to run, the only time the motor draws battery is when you start it.
The rest of the time you are charging the battery, it won't keep up with much more than nav. Lights and a spotlight though.
| Thu Aug 18, 2011 7:54 pm |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
24 hp huh maybe hondagx670 motor if so it has a 20 amp charging curcuit ! Don't need a trolling motor to kill ducks dump that shit long tails don't care for alot of weight If you HAVE to keep the extra stuff try distribute more weight up front
| Thu Aug 18, 2011 8:01 pm |
