It is currently Sat Apr 04, 2026 7:15 am
[ 6 posts ] |
Questions for the long tail Gooroos
jollygiant01
I have been around a few mud motors, longtails and surface drives, but never owned one. I got a good deal on a 31hp Vanguard and want to build it into a longtail. it will be used on a 16x50 boat
What size prop should I use?
Will a 3/4" shaft be enough?
and what is the advantage of running an angled shaft with a U-joint over a longer shaft run directly off of the engine?
| Thu Sep 01, 2011 9:46 pm |
outdoor freak
Joined: Fri Sep 02, 2011 10:06 pm Posts: 99 Location: michigan
 Re: Questions for the long tail Gooroos
dont quote me on thise but i believe that the longer the shaft the more power loss ive been told that 30 hp long tail runs as if it was 15hp also alot of motors have an low oil shut off and if the motor is on two much of an angle it wont run or you could blow the motor up by the oil running on one side of the motor
| Sat Sep 03, 2011 12:28 am |
GeeLeDouche
My suggestion is to run what all the major manufactor's run, and thats a U joint shaft. I think 3/4 will be plenty big. and I would go with a 9x7 prop. post pics of the build when you get it going.
| Sat Sep 03, 2011 6:58 am |
Woodiebuster
The big 31-35 lt shafts are 7/8 not 3/4
I would get a 10x4
| Sat Sep 03, 2011 7:16 am |
specgoos1222
Joined: Tue Oct 19, 2010 7:02 pm Posts: 46 Location: Great Bend, KS
| Mon Sep 05, 2011 7:49 pm |
lngtail24
Joined: Tue Sep 22, 2009 7:13 pm Posts: 210 Location: Mobile, AL
For sure use a 7/8 shaft but I prefer the 10x5 You give up a lot of speed with the 10x4
| Thu Sep 08, 2011 10:56 pm |
[ 6 posts ] |
