It is currently Sun Apr 05, 2026 6:19 pm
[ 6 posts ] |
Rendon_6
Joined: Sat Jun 04, 2011 12:45 pm Posts: 81 Location: Hooper, Utah
 Homemade Longtail
I am making a LT and have everything ready to go beside the lower bearing housing. I have two ideas of doing it.
1. I bought a pipe fitting thats 1 by 1 1/2 reducing, I would than weld the 1" side to the shaft housing and insert bearing in 1 1/2" side put a couple seals in and than a cap with a 3/4" hole.
2. Just find a pipe with a ID of 1 3/4" so the bearing snug, weld it onto the shaft housing, the other end machine threads in and have a couple seals and a cap with a 3/4" hole.
What do you all think would be better?
Any other ideas?
Thanks
| Thu Jul 21, 2011 4:10 pm |
specgoos1222
Joined: Tue Oct 19, 2010 7:02 pm Posts: 46 Location: Great Bend, KS
 Re: Homemade Longtail
Bronze bushings and seals. You would be amazed the variety of sizes they make.
| Thu Jul 21, 2011 10:39 pm |
scotts98rt
x2, beside much easier to assemble.
| Fri Jul 22, 2011 9:27 am |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
you need a bearing housing at the top, seal housing at the bottom. nothing big for your seal housing just something to keep em in place.
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
| Fri Jul 22, 2011 8:54 pm |
outdoor freak
Joined: Fri Sep 02, 2011 10:06 pm Posts: 99 Location: michigan
bronze bushing and locking collars tractor supply sell them
| Fri Sep 09, 2011 12:51 am |
Rendon_6
 Homemade Longtail
I found a bearing housings that would fit a tapered roller bearing that I have a shaft collar and than two seals than my cap
| Sun Sep 11, 2011 7:35 pm |
[ 6 posts ] |
