It is currently Thu Apr 02, 2026 9:40 am
Reply to topic  [ 3 posts ]
 Longtail Balance point question
Post Longtail Balance point question
I'm planing a home build 6.5hp longtail and would like to know where the pivot point should be. I have not run a mud motor so I don't have a hands-on feel for them.
Is it best to make it motor heavy, tail heavy, neutral? How heavy (pounds at tiller or prop) if not neutral? It will have a cav plate if that makes a difference.
Did a search, but didn't find my answer....
Thanks!
Sandor27
Thu Oct 06, 2011 8:04 am
Post Re: Longtail Balance point question
go to your local lt dealer and see what theirs is, it should be evenly balanced. the biggest factor is transom heighth, and makin sure your cav plate is leveled. i made mine a little tail heavy so it would dig a little easier, but not much so its not a pain to lift the prop. again, biggest issue is makin sur eyour cav plate is where it needs to be.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Thu Oct 06, 2011 9:11 am
I like mine just slightly tiller heavy when it breaks over level, so you don't have to tie it down every time you stop.
Fri Oct 07, 2011 3:58 pm
