It is currently Mon Apr 06, 2026 10:40 am
Reply to topic  [ 10 posts ]
 Throttle Cable
Post Throttle Cable
My factory installed throttle cable broke (Go Devil Van 23hp)and the set screw on the throttle lever is too rusted to simply attach a new one. I am looking for some ideas on replacing with something more practical and easy to obtain.
Scott
Thu Sep 29, 2011 8:40 pm
Post Re: Throttle Cable
Bicycle cable and brake lever? :D
1436 Lowe
Thu Sep 29, 2011 9:38 pm
x2 I had the ASV breakaway lever on my 23 LT worked great
Thu Sep 29, 2011 9:43 pm
New Member
16x48 War Eagle
31hp Vanguard Go Devil Longtail
Sat Oct 08, 2011 6:33 pm
I would think a regular pedal bike brake handle would be ideal. Plus you can get them in shorter handles like just the 2 finger pull models which may be handy cause you could rig it so just your pinkie and ring finger were on the throttle but yet keep the rest of your hand on the handle... Don't know have not done it yet, but thinking it would work pretty well.
Sun Oct 09, 2011 7:56 pm
Profile YIM
Has anyone tried a motorcycle twist grip which would make it like an outboard tiller? I don't see them on the factory set-ups so there's got to be a reason.
If your tiller handle is 7/8ths inch diameter this would work.
Mon Oct 10, 2011 6:29 am
Twist throttle + lt tiller torque = no bueno if it catches a bite.
Mon Oct 10, 2011 7:56 am
Tue Oct 11, 2011 8:15 am
i re-did my throttle all together. i got a new cable and switched out the leaver for one off of a tiller. I also put a stronger spring on it so it will "spring" back. heres a pic.
“I can only say that I am nothing but a poor sinner, trusting in Christ alone for salvation.”
― Robert E. Lee
Wed Oct 12, 2011 7:57 pm
Thanks for the tips!!!
Mon Oct 24, 2011 2:23 pm
