It is currently Sun Apr 05, 2026 8:13 pm
[ 3 posts ] |
bighunt70
Joined: Tue Oct 04, 2011 7:11 pm Posts: 37 Location: Southern swamp
 mods for 20hp longtail
do yall know any mods that i can put on my 20 hp vanguard go devil long tail to make it get more power and preferably more speed?
| Wed Nov 09, 2011 7:43 pm |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
 Re: mods for 20hp longtail
Without gear reduction, any money spent on this will be counterproductive. The cheapest tweak, if you have not already done this, is to advance the throttle to get around 4100 rpm's out of the water. This should get you maybe a 2 mph gain in the water. Any wear (been said a thousand times) on the prop will slow you down- well, there are exceptions on initial "break-in" where you can actually gain some speed if you have too much cup,etc.- so investing in a new prop is a good thing- you need a backup in any case. The mfg. can alert you to proper application depending on your elevation. A new set of plugs, an oil change, use of synthetic oil/grease, removing any foam "pre-cleaner" around the air filter, application of steelflex or smooth slick epoxy type finish on the hull bottom, adjusting the cavitation plate to optimize planing, moving the battery and/or gas tank up front and experimenting with balancing the load, are all relatively easy "mods". A hull less than 16' may warrant the use of transom pods, but they are not cheap, and if not done correctly, a mess-up. Just like a scattergun, there are limits to any longtail/hull combo.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Thu Nov 10, 2011 7:00 am |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Thu Nov 10, 2011 7:53 pm |
[ 3 posts ] |
