23hp vangard stalling out
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=23985
Author:  killkrew [ Sun Nov 13, 2011 6:43 pm ]
Post subject:  23hp vangard stalling out
i got a new 23hp vangard an it stalls out when im on the throttle for a good while any help on what can cause that would be appreciated thanks
Author:  duckduckboom [ Sun Nov 13, 2011 6:49 pm ]
Post subject:  Re: 23hp vangard stalling out
are you losing your fuel prime?
Author:  killkrew [ Sun Nov 13, 2011 6:54 pm ]
maybe a little but there is still sum gas in the inline fuel filter but not alot
Author:  duckduckboom [ Sun Nov 13, 2011 6:55 pm ]
pump your bulb next time and see if it starts running good again. If it does you might need a new fuel pump. I would try the bulb before you go any further
Author:  killkrew [ Sun Nov 13, 2011 7:04 pm ]
ok ill try that so by fuel pump do u mean i will need a new primer bulb?
Author:  duckduckboom [ Sun Nov 13, 2011 7:27 pm ]
follow your gas line until it runs into something like this
http://tewarehouse.com/7-08024?sc=2&category=30
your fuel pump should be similar.
Author:  cb5331 [ Sun Nov 13, 2011 7:55 pm ]
Sounds like an air leak in your fuel line, bad pump, or trash in the carb. Probably air or trash though.
Author:  killkrew [ Mon Nov 14, 2011 5:00 pm ]
ok cool ill try an track it down thanks for the help guys i appreciate it
Author:  killkrew [ Sat Nov 26, 2011 10:23 am ]
i took it back out today an it done it agin, i had allready went through an checked my gas line it seems to be fine, an its a brand new motor i have only had it out 6 times, but once i squeezed the primer bulb it would fire right up, but a lil bit after it would die out agin?
Author:  Hobbs081828 [ Sat Nov 26, 2011 1:04 pm ]
Gething air in the fuel line somewhere check all hose clamps
Author:  cmartin1985 [ Tue Nov 29, 2011 2:35 pm ]
This has happened to me before and I did the same thing as far as checking all the possible gas problems. What it ended up being for me was the oil level. Apparently I had too much oil in the motor, and after running for a while, the oil level would rise and cause the motor to bogg down. Maybe try taking out a little oil and see if that helps.
Author:  SubDuck [ Fri Dec 02, 2011 9:20 pm ]
My Vanguard 23 did the same thing to me when I first bought it and I could not figure out what was wrong. It was under warranty so I took it to the local service provider and he said there was some "trash" in the carb and he flushed the carb and it has ran like a champ ever since.
