It is currently Sat Apr 04, 2026 12:22 pm
[ 6 posts ] |
swamprat26
 How much
I have a new 16hp gd lt and when running open water my cavitation plate is just below the water and runs fine. As soon as i hit grass it pops out and i have to force it down. It is not hard to do. Is this normal? My first longtail. Im scared if i adjust the cavitation plate it will be too deep in open water. Not sure if this is normal or not.
| Fri Nov 18, 2011 10:00 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: How much
Bend it a little at a time till you get it right, process of elimination
| Fri Nov 18, 2011 10:02 pm |
Woodiebuster
 Re: How much
Its normal, welcome to the bitch that is a balanced frame.
The cav. plate is for deep water adjustment.
| Fri Nov 18, 2011 10:03 pm |
swamprat26
 How much
Thanks. Its not bad. Just my first lt and wasnt sure if it was normal.
| Fri Nov 18, 2011 10:04 pm |
swampstomper
Joined: Mon Feb 07, 2011 7:00 pm Posts: 40 Location: Abita Springs, La.
 Re: How much
How fast are you going through the grass? What kinda grass are you talking about? If you go slow the grass will try to bunch up and pull the prop down. Thick hydrilla will stop you if you try to go slow. Hit it wide open when the prop blows out the water just hold it down in the thicker stuff and let it eat! SS
| Sat Nov 19, 2011 6:00 pm |
swamprat26
 How much
Thats what i do. Its hard to hold down in thick grass wide open. But i only have two hours running a long tail and im learning. Had fun today and it did good.
| Sat Nov 19, 2011 6:10 pm |
[ 6 posts ] |
