It is currently Thu Apr 02, 2026 9:31 am
Reply to topic  [ 7 posts ]
 Homemade longtial?- U-joint
Post Homemade longtial?- U-joint
Building a longtail and need help with the u-joint. My motor shaft is 5/8 and my drive shaft is ¾. Both have 3/16 keyways. Transom is 16 inches and drive shaft is 72”. I’ve been trying to research u-joints on other builds but I can’t figure this last part out. Can someone give me advice on a part or model number? Thanks for the help.
Sat Nov 19, 2011 9:15 pm
Post Re: Homemade longtial?- U-joint
mcmaster.com
Sat Nov 19, 2011 9:53 pm
I think you are needing the yoke sizes. Napa and tractor supply also carry these. you can mix the shaft diameter sizes as long as they accept the same size u-joint.
Sun Nov 20, 2011 11:03 am
Sun Nov 20, 2011 11:29 am
Sweet, thanks guys.
Sun Nov 20, 2011 9:29 pm
http://www.driveshaftparts.com/
They have a mix and match set, you pick your shaft sizes and they sell you both yokes and a joint for $25
Tue Nov 22, 2011 1:53 pm
FYI, you need the 1000 series kit on the front page
Tue Nov 22, 2011 1:54 pm
