It is currently Mon Apr 06, 2026 8:17 am
Reply to topic  [ 16 posts ]
 Steering issue
Post Steering issue
I've had a 4' wide jon boat for years that I would put around the canals in with a trolling motor. This year I decided to put a mud motor on it. I found a reasonably priced used deal from a guy on craigslist and slapped it on. I'm wondering if I made a big mistake. The tiller comes up on my right side so if I am making a right hand turn my body is in the way of the rotation. The only way I see around this is to steer behind me which I find very uncomfortable, and really impossible if I am making a sharp right. Unless I 'm missing something it seems to me you need a boat with enough beam and stability that you can move your body with the tiller. Am I wrong? :?:
Mon Nov 21, 2011 11:38 am
Post Re: Steering issue
You are driving it with your left hand, arent you?
Mon Nov 21, 2011 12:08 pm
Mon Nov 21, 2011 12:10 pm
Post pics.
Mon Nov 21, 2011 12:14 pm
What side of the motor is the tiller attached (port or starboard)?
Mon Nov 21, 2011 12:22 pm
Post Steering issue
17x48 extreme stage 2 GTR
Mon Nov 21, 2011 12:30 pm
Mon Nov 21, 2011 12:37 pm
Move the tiller to the other side of the engine. Sounds like some kinda jacked up home build.
Mon Nov 21, 2011 12:46 pm
Mon Nov 21, 2011 1:02 pm
post pics.
Mon Nov 21, 2011 1:03 pm
As cb said, you need to post a pic of it. On all production made motors the handle is mounted to the port side, but also they are bent in a way that allows you to make "normal" turns with ease. If you intend on making a sharp turn, yea, you must swing the handle behind you, and there is nothing you can do about that.
Mon Nov 21, 2011 1:08 pm
Mon Nov 21, 2011 1:24 pm
Post Steering issue
You are supposed to swap sides to make turns. They are all that way because of the long handle, to deal with torque. In your case, your handle is just opposite than normal.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon Nov 21, 2011 2:24 pm
Mon Nov 21, 2011 2:50 pm
If your boat is 4' wide that is not small just get out in open water and practice driving it ... I've got a 20 hp gdlt and I'm still getting used 2 driving it
Wed Nov 23, 2011 8:31 am
so how are u doing driving the mud motor? u can install a handle (grab bar), that will h elp with ur balance. but a four foot wide bottom boat should bbe plenty stable i got a 1436 with a 20 hp. btlt
Thu Dec 08, 2011 9:20 am
