It is currently Tue Apr 07, 2026 8:20 am
Reply to topic  [ 13 posts ]
 Prop loose?
Post Prop loose?
Unsure how this happened, anyways noticed alot of vibration coming from the lower prop area today while hunting, eased over to a bank to further inspect and it seems my prop came loose between the nuts the prop is threaded. If this makes no sense tell me i'll snap a pic when I get home.
16' skiff 23 GDLT
Sat Dec 17, 2011 5:45 pm
Post Re: Prop loose?
So my question is which end do I tighten the prop all the way then the 2 bolts down?
16' skiff 23 GDLT
Sun Dec 18, 2011 11:16 am
Remove the whole thing, APPLY ANTI SEIZE LIBERALLY and sandwich prop between nuts shown in picture. I put front nut on, then prop (I give mine a couple wacks with piece of 2x4 to tighten against front nut) then add the back two nuts. Mine never comes loose. DON'T FORGET ANTI SEIZE!
Sun Dec 18, 2011 11:24 am
It is supposed to have about 1/2 turn slack
Your vibe is probably due to your lower bushing worn and or needing grease
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sun Dec 18, 2011 11:28 am
Seems odd that this would happen guess it worked itself loose? So, I can tighten the prop up against the upper nut (hand tighten? top pic) then apply some never seez and the reinstall the nut, lock washer, locknut. Should I hand tighten the the first nut up to the prop then, torque the lock nut to it? Sorry this is such a grammatical shit storm its hell typing from a phone.
16' skiff 23 GDLT
Sun Dec 18, 2011 4:12 pm
Post Prop loose?
Leave enough slack in the prop so it can turn about a half turn.
Sun Dec 18, 2011 4:34 pm
Post Prop loose?
I snug my prop after applying nickel based anti-seize. Then, tighten last two nuts. Never have a problem getting them off. I've had the shaft threads get worn, from letting the prop float, causing vibration.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun Dec 18, 2011 6:04 pm
Post Prop loose?
I just bought a new 16 from go devil. Had to bring it back because it had too much cup. Couldnt get the RPM's above 2900. When I brought it to the back i watched them remove and install it. He tughtened the prop hand tiight and snugged the the two nuts with a lg crescent wrench. No torque wrench
Sun Dec 18, 2011 6:08 pm
Sun Dec 18, 2011 6:16 pm
Post Prop loose?
They did put a lot of nikkel ease on it
Sun Dec 18, 2011 6:27 pm
WTH? Who sells the anti seize? Can't find it anywhere but online.
16' skiff 23 GDLT
Sun Dec 18, 2011 7:40 pm
Post Prop loose?
Any napa auto zone or lowes
Sun Dec 18, 2011 7:48 pm
Google "LPS Nickel anti-seize."
Sun Dec 18, 2011 8:04 pm
