It is currently Sat Jun 21, 2025 2:41 pm
[ 7 posts ] |
lakeduckhunter
 go Devil Question?
Hello all, I bought a used Go Devil longtail and it came with an 8 horse Briggs and stratton motor already mounted on it and a 13 horse Honda motor with electric start. I tok the 8 off to see if the Honda would bolt on and it will with a few holes drilled. My question is when I switch motors will I have to get a different prop for the 13 honda. The prop I have now is going to have to be replaced either way just curious if I need to go up a size. Also anywhere I can get a prop from, Go Devil is expensive. Thanks
Mon Jan 26, 2009 12:29 pm |
mcnemar1982
Joined: Mon Jan 19, 2009 4:03 pm Posts: 2216 Location: Walker, Louisiana
 Re: go Devil Question?
Props on ebay.
_________________ Ideas not coupled with action never become bigger than the brain cells they occupied.
Owner DEEP SOUTH CUSTOM BOATS (225) 252-2700 Good boats ain't cheap, Cheap boats ain't good!
Mon Jan 26, 2009 9:05 pm |
lakeduckhunter
I have seen the props on ebay but was also wondering if I needed to adjust my prop size for the bigger motor. I think a 9x3 will work but the 8x4 is what I have now when it is new. thanks
Wed Jan 28, 2009 7:16 am |
Gigafowl
Just guessing but the original prop is 2 or three generations old - if the unit is over 10 years old - like mine....
GoDevil uses the 9x3 on a 16 hp - so it is likely to be too much for the 10 hp.... Alo the frame might not work well with the larger diameter...
However GoDevil's current 8x4 is a better prop than what they had 10 years ago...
I'd go with the GoDevil 8x4 - if it is in your budget - if not check with some prop rebuilders and just rework the old one or buy a rebuilt from the prop rebuilders
Thu Jan 29, 2009 10:31 pm |
lakeduckhunter
Thanks for the reply. I will probably be buying the 8x4 for the 13 hp motor. I don't think that the 9x3 would fit anyhow. Thanks for the replys.
Fri Jan 30, 2009 6:18 am |
ggoodman
be sure and post up how it goes for future refrence by others. GG
Sun Mar 01, 2009 6:22 pm |
Mike W.
Joined: Thu Jan 15, 2009 2:26 pm Posts: 146 Location: Vanceboro, NC
Go-Devil recommends a 9x3 for a 16HP. Give them a call and thy will send you in the right direction. www. godevil.com
_________________ "They call us civilized, cause we're easy to sneak up on!"
Sun Mar 01, 2009 7:32 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 64 guests |
