It is currently Sat Apr 04, 2026 8:47 am
[ 8 posts ] |
Pressure Lubricator Question
bayouboy263
I have the Alemite Pressure Lubricator on my Long Tail. Recently it has been oozing grease from under the cap while I am running. What do ya'll think is causing this?
I currently have the "lightest" spring in the lubricator. Could this be the problem?
| Sat Dec 17, 2011 8:48 pm |
autogateman
The seal that pushes the grease down in to the shaft housing is bad. Just replace the whole thing, no grease should be between the cap and the seal.
| Sat Dec 17, 2011 8:55 pm |
bayouboy263
 Re: Pressure Lubricator Question
Thanks.
| Sat Dec 17, 2011 9:18 pm |
Bayport
| Fri Dec 23, 2011 7:46 pm |
autogateman
There is a seal around the plunger in the lubricator.
| Fri Dec 23, 2011 9:04 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
fill the cup max 3/4 full also
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
| Fri Dec 23, 2011 9:28 pm |
kibb
^x2. If you fill it all the way to the top, when the grease in the shaft heats up it either gonna blow through the bushing seals or take a dump in the lubricator.
| Fri Dec 23, 2011 9:32 pm |
Bayport
thanks
| Sun Dec 25, 2011 8:39 am |
[ 8 posts ] |
