| Pressure Lubricator Question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=25001 |
| Author: | bayouboy263 [ Sat Dec 17, 2011 8:48 pm ] |
| Post subject: | Pressure Lubricator Question |
I have the Alemite Pressure Lubricator on my Long Tail. Recently it has been oozing grease from under the cap while I am running. What do ya'll think is causing this? I currently have the "lightest" spring in the lubricator. Could this be the problem? |
| Author: | autogateman [ Sat Dec 17, 2011 8:55 pm ] |
The seal that pushes the grease down in to the shaft housing is bad. Just replace the whole thing, no grease should be between the cap and the seal. |
| Author: | bayouboy263 [ Sat Dec 17, 2011 9:18 pm ] |
| Post subject: | Re: Pressure Lubricator Question |
Thanks. |
| Author: | Bayport [ Fri Dec 23, 2011 7:46 pm ] |
| Author: | autogateman [ Fri Dec 23, 2011 9:04 pm ] |
There is a seal around the plunger in the lubricator. |
| Author: | da go get'er [ Fri Dec 23, 2011 9:28 pm ] |
fill the cup max 3/4 full also |
| Author: | kibb [ Fri Dec 23, 2011 9:32 pm ] |
^x2. If you fill it all the way to the top, when the grease in the shaft heats up it either gonna blow through the bushing seals or take a dump in the lubricator. |
| Author: | Bayport [ Sun Dec 25, 2011 8:39 am ] |
thanks |
