hit something, then wouldnt start
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=25025
Author:  Jw261 [ Mon Dec 19, 2011 7:19 am ]
Post subject:  hit something, then wouldnt start
Yesterday I was running across a hard bottom oyster bed and hit something really hard that kicked the prop out of the water. Probably a log or something. It caused the motor to stall and then when I tried to start it up it would run for about 15 seconds really rough and stall. After about 5 minutes it started and ran fine. I am just a little worried there is something I need to address or if yall have any ideas why this happened.
Author:  hunt682 [ Mon Dec 19, 2011 8:08 am ]
What kind of motor
Sent via telegraph
Author:  Jw261 [ Mon Dec 19, 2011 8:12 am ]
Post subject:  Re: hit something, then wouldnt start
sorry. 16 hp gdlt.
Author:  backwater86 [ Mon Dec 19, 2011 8:56 am ]
Had the same problem with my 18 all i could figure was a sudden shut down at WOT causes the motor to load up when trying to restart you could smell the unburnt fuel from the exhaust
Author:  Jw261 [ Mon Dec 19, 2011 10:24 am ]
Yeah, I did smell some fuel when I was cranking it because I was worried I had flooded it somehow. It acted like it wanted to stall when I would try to put the prop in the water. Could that switch that won't allow you to start it without the motor being level have gotten shook up from the impact?
Author:  Woodiebuster [ Mon Dec 19, 2011 6:13 pm ]
It might have sheared a flywheel key, but I doubt it.
Author:  Jw261 [ Mon Dec 19, 2011 10:02 pm ]
I was scared that it had sheared a key at first. I assumed not after it ran the rest of the day without any further problems. I am sure I am worrying over nothing. It runs OK now. I just wondered if there was a common reason for the motor acting like it did.
Author:  da go get'er [ Tue Dec 20, 2011 8:22 am ]
[quote="Jw261"]Yeah, I did smell some fuel when I was cranking it because I was worried I had flooded it somehow. It acted like it wanted to stall when I would try to put the prop in the water. Could that switch that won't allow you to start it without the motor being level have gotten shook up from the impact?[/quote]
If your talking about the mercury switch then no that wouldn't even let your motor turn over.
