It is currently Sun Apr 05, 2026 4:10 pm
Reply to topic  [ 11 posts ]
 New to MMT
Post New to MMT
Also new to longtails. Bought a 20hp MBLT on a 1648 grizzly. Looks to me like previous owner greased the hell out of it or wondering if seals are shot. Prop is in decent shape. Last time out I had a lot of grease coming out of the top of the shaft and the prop started slinging some around too. Thoughts?
Fri Apr 05, 2013 3:39 pm
Post Re: New to MMT
How many hours are on it? It shouldn't be slinging copious amounts of grease. As far as the prop is concerned , you should probably measure it. Props can look ok and have 1/2 an in missing, which can make all the difference in the world .
Semper Fi
16x38 WC Skiff 35 MB HD
Fri Apr 05, 2013 5:21 pm
Post Re: New to MMT
I don't know. But if grease is coming out by the spoon full, I would think your seals are gone.
Fri Apr 05, 2013 5:27 pm
Post Re: New to MMT
Based on what I see, I would say yes, replace the seals. You probably need new seals on the bottom and possibly a new shaft. I just went through this with a used go devil 23 I bought. I was hesitant to do it myself, but after reading the owners manual and talking with the owner of go devil several times, I dove into it. I have a better understanding of how it all works and I am glad I did it.
Fri Apr 05, 2013 8:04 pm
Post Re: New to MMT
16/42 crawfish skiff - 31GDLT
Fri Apr 05, 2013 8:32 pm
Post Re: New to MMT
Post Re: New to MMT
Post Re: New to MMT
Fri Apr 05, 2013 8:37 pm
Post Re: New to MMT
First off, congrats! Secondly, being a "new to you" motor, I'd replace seals, bushings, bearing, shaft, and prop. That's a few extra hundred dollars that'll give you peace of mind knowing all the critical components are brand new and will last a good while.
Then run the fire out of it!
Fri Apr 05, 2013 9:29 pm
Post Re: New to MMT
10-4 on what Frank said. The GD LT I had (both of them) oozed a lot of grease so I typically carried a grease gun. Not so with the MB roller bearing setup. I grease it a lot less. Parts are not that expensive and so it is worth the investment to replace these so you don't have a failure/breakdown. In the MB manual it clearly states the dangers of over-greasing the bearings. Happy mudding!
Sat Apr 06, 2013 1:37 am
Post Re: New to MMT
Thanks for the replies and suggestions. I'll have to give MB a call and get that ordered.
Sat Apr 06, 2013 3:17 pm
