It is currently Sun Apr 12, 2026 5:35 pm
Reply to topic  [ 4 posts ]
 shaft grease
Post shaft grease
do I fill the entire shaft with grease, or just the lower zerk and upper zerk?
Wed Jan 04, 2012 5:52 pm
Post Re: shaft grease
Pump the lower zerk up until it pushes the seal up about 3/4 of the way in the pressure lubricator. Don't pump grease into the zerk on the pressure lube housing.
Wed Jan 04, 2012 7:57 pm
Do I need to put any in the top zerk?
Wed Jan 04, 2012 8:11 pm
Yep. Lube the pivot and swivel zerks on the mount plate while you're at it.
Wed Jan 04, 2012 8:29 pm
