| is it my prop or boat http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=25534 |
| Author: | 24 BEAVERTAIL [ Fri Jan 06, 2012 10:39 pm ] |
| Post subject: | is it my prop or boat |
I got a 15/46 alweded boat with a 24 hp beavertail and running 10.5 with me and another guy me 185 him 120 I made him get out with the same load by my self im only running 12.3 is this right or do I need a new prop or is my boat to short my prop is kinda wore but I thought a smaller prop was better for running a heavier load |
| Author: | scatters boy 316 [ Fri Jan 06, 2012 10:44 pm ] |
| Post subject: | Re: is it my prop or boat |
i would replace the prop first, how many hours have you had the prop? |
| Author: | 24 BEAVERTAIL [ Fri Jan 06, 2012 10:55 pm ] |
I have only ran this motor two season s the prop was new when I got the motor I bought it used last year before duck season |
| Author: | scatters boy 316 [ Fri Jan 06, 2012 10:58 pm ] |
2 seasonsis a long time for a prop especially if you run hard or sandy bottom or both, so its more than likely the prop and not your boat |
| Author: | autogateman [ Fri Jan 06, 2012 11:01 pm ] |
whoa hold up man. dont go buy a new prop just yet, you need to be looking at what rpm's youre turning at wide open. get a tiny tach if you dont have one. more than likely youre motor isnt 'opening up' all the way |
| Author: | Woodiebuster [ Fri Jan 06, 2012 11:02 pm ] |
It can definitely smoke a prop in two seasons. What RPM's are you running? |
| Author: | indawoods [ Fri Jan 06, 2012 11:16 pm ] |
measure your prop, tip to tip. how far out of spec is it? |
| Author: | 24 BEAVERTAIL [ Sat Jan 07, 2012 8:18 am ] |
I dont have a tach I did let the srew out on the throttle its maxed out now when it s wide open its plate to plate ill measure the prop |
| Author: | 24 BEAVERTAIL [ Sat Jan 07, 2012 7:27 pm ] |
the prop only measures eight inches at its longest point tip to tip its a little shorter than that |
| Author: | indawoods [ Sat Jan 07, 2012 10:48 pm ] |
it should measure 9 inches, you need a new prop, regardless of whether or not there is/isn't a RPM issue. Put a new prop on it to eliminate that problem, then invest in a tiny tach and post your RPMs in and out of water. we can go from there. |
