It is currently Sat Apr 11, 2026 6:51 am
Reply to topic  [ 8 posts ]
 3 blade godevil surface drive prop on longtail
Post 3 blade godevil surface drive prop on longtail
Has anyone heard of or tried a 3 blade surface drive prop on a longtail ?
Sat Jan 21, 2012 8:51 pm
Post Re: 3 blade godevil surface drive prop on longtail
Not a surface drive blade. My first LT was a GD 18 HP, that was on a 1436 jon boat. I ran a 3 bladed prop GD offered back in '92...it was great in clean water but got bogged down as soon as I hit any grass- it was not a SW blade. Maybe it's unworkable to create a super weedless 3 bladed LT (under the surface) prop? Good question, any engineers out there?
Sun Jan 22, 2012 3:15 am
Thanks , I guess it works better on the sd because of the belt and pulley reduction
Sun Jan 22, 2012 7:53 am
I had a 3 bladed prop on my first longtail and it did pretty well. My lontail was alot faster with the 3 blade, but I called go-devil and they said they discontinued making them. Im not sure how a surface drive prop would run on a longtail but it could be worth a shot. It seems like the diameter may be to large.
1542 War Eagle with 25hp GDLT
Sun Jan 22, 2012 10:30 am
Too much prop
Sun Jan 22, 2012 8:06 pm
Sun Jan 22, 2012 8:13 pm
Thier newer design is definitely good I just changed from an aftermarket to a gd prop and picked up 4 mph and way more bottom end
23HP GO-DEVIL longtail pushing a 1750 Mike Kliebert custom
Mon Jan 23, 2012 9:05 pm
I tried a 3 blade GDSD prop on my 31hp LT an its for sure too much prop! The biggest an best prop i have ran yet is a 10x7 aftermarket prop for both top and bottom end!
Tue Feb 21, 2012 10:42 pm
