It is currently Sat Apr 04, 2026 7:52 pm
Reply to topic  [ 11 posts ]
 23 hp speeds
Post 23 hp speeds
Buying a gdlt23 hp tonight and curious about what speeds I will be getting on a 1448 mv hull?
Tue Feb 28, 2012 9:32 am
Post Re: 23 hp speeds
With a 27 BTLT on a 1448 im gettin 20 empty and loaded turnin 4200 rpms
Tue Feb 28, 2012 11:11 am
I had the same rig before, boat was welded. No speed demon. If I remember correctly, 15-17 empty with just me 200lbs. 2 guys, loaded with hunting gear 12-14. If more weight or third guy, plowing water maybe 10.
Make sure to get your wieght distrubuted right.
MB 35hp LT/1754 Grizzly
Tue Feb 28, 2012 5:10 pm
be happy with 17 by yourself, less with a load.
Wed Feb 29, 2012 4:29 pm
Probably looking at the 15-17 yourself
13-15 with a load.
Send us what speeds you're running if you got it already. Educate the forum as I'm sure a lot more people will be looking for this info on similair rigs in the future...
B. MacDonald
Wed Feb 29, 2012 4:34 pm
Post 23 hp speeds
Me and my dad and hunting gear got 16-17 in a 1754 with a tall transom. Unless my gps was off and yes it was laying down not in my hand
Sent via telegraph
Wed Feb 29, 2012 4:40 pm
i know this is gonna sound like BS but im getting 17-18 in a 1750 round chine with myself 150, a buddy 250 and a 60 lbs lab and 4 dozzen deeks. but i do have a ported intake and a new gd prop.
23HP GO-DEVIL longtail pushing a 1750 Mike Kliebert custom
Wed Feb 29, 2012 9:12 pm
ran it for the first time tonight.....running a 9x7 prop and seemed to move pretty good with 2 people blind dog toolbox and 2 5 gallon buckets of crappie o and fishing poles....i have a heavy ass wooden floor and some extra weight im wanting to get rid of but ill post speeds tomorrow as i will run the river with it.....it turned out to be a crawfish model 16hp upgraded to a 23.....seems to have tons of torque
Wed Feb 29, 2012 9:56 pm
Definitely get rid of the wooden floor and invest in an alum sheet, I used .090, and I put some closed cell insulation under it and between the ribs for a snug and quiet/insulated fit and finish. It weighs considerably less and won't rot. I also moved the battery up front under the bow (left the gas in the back) for better weight distribution. Another good investment is to steelflex the bottom of the hull. If you have the foam precleaner around the air filter, remove that. Go synthetic with both oil and grease. If you have not done so, as was indicated in the previous post, tweak your throttle to around 4200 rpm out of the water.
Thu Mar 01, 2012 4:39 am
Thu Mar 01, 2012 12:23 pm
not sure....but im guessing they just bolted it up....the guy wouldnt admit he altered it....its pretty nice...pushed up the wabash river with me(170) and another guy (220) and bowfishing geer and a treestand at 15 mph...even with that damn wooden floor....by myself im pushing 18
Thu Mar 01, 2012 8:54 pm
