It is currently Mon Apr 06, 2026 2:26 am
[ 7 posts ] |
ottertailriverrunner
Joined: Fri Oct 02, 2009 4:46 pm Posts: 79 Location: Otter Tail County, MN
 16 vanguard fuel pump
Last fall at the end of duck season my 16 vanguard gdlt stopped pumping gas. Over the winter I replaced the pump and fuel lines to the carb and the short vacuum line. I also removed the inline fuel filter. The bulb will keep a good prime. Fittings on the tank are tight and the fuel line is good. Started it up today for the first time since last fall and it still won't suck gas through the fuel pump. As soon a I pump the bulb it takes right off again for 30 seconds until it runs out of gas. Any guesses on this one? Thanks for any info...
| Wed Mar 21, 2012 8:05 pm |
KaCajun Boy
Joined: Tue Nov 01, 2011 2:43 am Posts: 179 Location: SELA
 Re: 16 vanguard fuel pump
Where did you get your fuel pump from? I got a 18hp gdlt and I'm looking for an electric fuel pump for mine.
_________________ 23hp GDLT on 16x38 GD boat When up to your nose in shit, don't open your mouth.
| Wed Mar 21, 2012 10:41 pm |
Buzz Killington
Not trying to insult - your vent on the tank is open?
B. MacDonald
| Thu Mar 22, 2012 6:08 am |
It's not a electric pump and there is no shut off valve on the tank. It will run all day long if I pump the bulb every 30 sec
| Thu Mar 22, 2012 6:34 am |
Buzz Killington
I meant the Vent on the gas tank - my bad.
B. MacDonald
| Thu Mar 22, 2012 7:12 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
| Fri Mar 23, 2012 3:57 pm |
KaCajun Boy
Hey thanks garjacker I been looking for a website.
| Fri Mar 23, 2012 9:59 pm |
[ 7 posts ] |
