It is currently Mon Jun 23, 2025 1:28 pm
Reply to topic  [ 9 posts ]
 GD pressure lube indicator
Post GD pressure lube indicator
What do you do when the pressure lube indicator on the Shaft fills up all the way?? I just bought a new Go-devil 9hp and my cap is starting to get full.
Thanks!! :mrgreen: :mrgreen: :mrgreen:
Wed Jun 24, 2009 11:47 pm
Post Re: GD pressure lube indicator
quit pumping.
1854 GTB with a stock (for now) 35 GTR
Thu Jun 25, 2009 5:07 am
:roll: X2
WC 1848 Bateau w/ 36 PD FPR
Thu Jun 25, 2009 7:19 am
U can't forking fix stupid ! River please help on this one. :roll:
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Thu Jun 25, 2009 9:14 am
Mud man - sounds like you are takin good care of it - if you unscrew the lil thingy it will poop out it's grease and you can start over - just pump till the level moves just slightly in the thingy each maintenance greasing
Thu Jun 25, 2009 9:52 am
Why is there a zirk in the side of it then?? Ya I know, I'm not pumping grease into it but I thought there was a different way to bleed the cup. So when it's full that seal inside must just pop out and you can scoop out all the old grease huh!? Ya I may be over doing it but I put one pump of grease in each zerk after a long use. It's an awsome motor I want it to last!
Not that I'm forking stupid! :evil: Just new to longtails!!! :evil: :evil:
Thu Jun 25, 2009 11:31 am
These motors are not the only applications these lubricators can be used for. The lubricator in this particular application is not greased on the lubricator probably because Go-Devil wants you to grease the middle zerk to insure the lower and middle bushing is properly greased. The lubricator here more or less catches the overflow and then lubes the lower and central bushings as needed. Just grease it until its full at every use, take the cap off once a year and pump fresh grease into the middle shaft zerk until all the old grease is out, and you're good to go.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Thu Jun 25, 2009 5:44 pm
Thank you very much "kibb"!!! That's What I was looking for some information!!! Not for some smart ass comment that mcnemar1982 sent!! :roll:
Thanks for the help!!
mcnemar1982 :roll: :roll: :roll:
Thu Jun 25, 2009 10:33 pm
Take it with a grain of salt.
Owner
Fri Jun 26, 2009 6:12 am
Users browsing this forum: No registered users and 62 guests
