david95
Joined: Thu Jan 12, 2012 5:15 pm Posts: 641 Location: Summerville, South Carolina
 27hp GDLT shaft and seals
Hi, I have a 27hp GDLT and i have to now replace the shaft and lower seals. I was wondering how hard this is gonna be and how long about? Any info would be great. thank you.
_________________ 27 GDLT pushing a War Eagle 1542
| Mon Mar 26, 2012 2:48 pm |
Buzz Killington
Fairly simple actually Pending all goes to plan and nothing breaks. Remove prop and nuts; Remove upper yoke; Remove upper seal; Pull shaft from the bottom; Replace lower seals; Replace shaft in reverse order...
Should be 25 min start to finish. I'd replace all the shaft grease while I'm at it.
B. MacDonald
| Tue Mar 27, 2012 5:49 am |
david95
 Re: 27hp GDLT shaft and seals
Well hopefully it all goes right dont sound to bad at all. I really appriciate the reply thanks.
| Tue Mar 27, 2012 6:24 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
For more details on the procedure you can go to the GoDevil website and download the maintenance manual in a PDF file. http://www.godevil.com/documents/Go-Dev ... Manual.pdf
_________________ so many rivers, so little time
| Tue Mar 27, 2012 10:57 am |
david95
Thanks I'm gonna take a look at it.
| Tue Mar 27, 2012 1:57 pm |
Buzz Killington
B. MacDonald
| Tue Mar 27, 2012 6:02 pm |
david95
Thanks, I will. I will post pictures through the process.
| Tue Mar 27, 2012 6:58 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
hey if you're gonna replace the shaft save yourself some trouble. pull the shaft then put it in a vice and break the prop loose. thats the hardest part of the whole procedure. i would invest in an inexpensive 3/4-10 tap and die. chase the threads on prop and shaft each time you service.
| Tue Mar 27, 2012 7:23 pm |
david95
Garjacker, I will try to get that prop off but man it's really on there. If I can get it then I will go with your suggestion. I appriciate it.
| Tue Mar 27, 2012 7:59 pm |
david95
Just ordered all the parts and there on the way. Hopefully get them tuesday and be back on the water next weekend!
| Thu Mar 29, 2012 3:44 pm |
david95
Parts came in today gonna hopefully get it done tommorow with no problems! I cant wait pretty excited.
| Tue Apr 03, 2012 8:02 pm |
david95
Got it all done tonight, can't wait to try it out Saturday with the new prop hopefully tear some shiii up!
| Wed Apr 04, 2012 7:35 pm |
