| 27hp GDLT shaft and seals http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=27948 |
| Author: | david95 [ Mon Mar 26, 2012 2:48 pm ] |
| Post subject: | 27hp GDLT shaft and seals |
Hi, I have a 27hp GDLT and i have to now replace the shaft and lower seals. I was wondering how hard this is gonna be and how long about? Any info would be great. thank you. |
| Author: | Buzz Killington [ Tue Mar 27, 2012 5:49 am ] |
Fairly simple actually Pending all goes to plan and nothing breaks. Remove prop and nuts; Remove upper yoke; Remove upper seal; Pull shaft from the bottom; Replace lower seals; Replace shaft in reverse order... Should be 25 min start to finish. I'd replace all the shaft grease while I'm at it. |
| Author: | david95 [ Tue Mar 27, 2012 6:24 am ] |
| Post subject: | Re: 27hp GDLT shaft and seals |
Well hopefully it all goes right dont sound to bad at all. I really appriciate the reply thanks. |
| Author: | stualaska [ Tue Mar 27, 2012 10:57 am ] |
For more details on the procedure you can go to the GoDevil website and download the maintenance manual in a PDF file. http://www.godevil.com/documents/Go-Dev ... Manual.pdf |
| Author: | david95 [ Tue Mar 27, 2012 1:57 pm ] |
Thanks I'm gonna take a look at it. |
| Author: | Buzz Killington [ Tue Mar 27, 2012 6:02 pm ] |
| Author: | david95 [ Tue Mar 27, 2012 6:58 pm ] |
Thanks, I will. I will post pictures through the process. |
| Author: | garjacker [ Tue Mar 27, 2012 7:23 pm ] |
hey if you're gonna replace the shaft save yourself some trouble. pull the shaft then put it in a vice and break the prop loose. thats the hardest part of the whole procedure. i would invest in an inexpensive 3/4-10 tap and die. chase the threads on prop and shaft each time you service. |
| Author: | david95 [ Tue Mar 27, 2012 7:59 pm ] |
Garjacker, I will try to get that prop off but man it's really on there. If I can get it then I will go with your suggestion. I appriciate it. |
| Author: | david95 [ Thu Mar 29, 2012 3:44 pm ] |
Just ordered all the parts and there on the way. Hopefully get them tuesday and be back on the water next weekend! |
| Author: | david95 [ Tue Apr 03, 2012 8:02 pm ] |
Parts came in today gonna hopefully get it done tommorow with no problems! I cant wait pretty excited. |
| Author: | david95 [ Wed Apr 04, 2012 7:35 pm ] |
Got it all done tonight, can't wait to try it out Saturday with the new prop hopefully tear some shiii up! |
