It is currently Mon Apr 06, 2026 9:44 pm
Reply to topic  [ 12 posts ]
 27hp GDLT shaft and seals
Post 27hp GDLT shaft and seals
Hi, I have a 27hp GDLT and i have to now replace the shaft and lower seals. I was wondering how hard this is gonna be and how long about? Any info would be great. thank you.
27 GDLT pushing a War Eagle 1542
Mon Mar 26, 2012 2:48 pm
Fairly simple actually
Pending all goes to plan and nothing breaks.
Remove prop and nuts;
Remove upper yoke;
Remove upper seal;
Pull shaft from the bottom;
Replace lower seals;
Replace shaft in reverse order...
Should be 25 min start to finish. I'd replace all the shaft grease while I'm at it.
B. MacDonald
Tue Mar 27, 2012 5:49 am
Post Re: 27hp GDLT shaft and seals
Well hopefully it all goes right dont sound to bad at all. I really appriciate the reply thanks.
Tue Mar 27, 2012 6:24 am
For more details on the procedure you can go to the GoDevil website and download the maintenance manual in a PDF file.
http://www.godevil.com/documents/Go-Dev ... Manual.pdf
Tue Mar 27, 2012 10:57 am
Thanks I'm gonna take a look at it.
Tue Mar 27, 2012 1:57 pm
B. MacDonald
Tue Mar 27, 2012 6:02 pm
Thanks, I will. I will post pictures through the process.
Tue Mar 27, 2012 6:58 pm
hey if you're gonna replace the shaft save yourself some trouble. pull the shaft then put it in a vice and break the prop loose. thats the hardest part of the whole procedure. i would invest in an inexpensive 3/4-10 tap and die. chase the threads on prop and shaft each time you service.
Tue Mar 27, 2012 7:23 pm
Garjacker, I will try to get that prop off but man it's really on there. If I can get it then I will go with your suggestion. I appriciate it.
Tue Mar 27, 2012 7:59 pm
Just ordered all the parts and there on the way. Hopefully get them tuesday and be back on the water next weekend!
Thu Mar 29, 2012 3:44 pm
Parts came in today gonna hopefully get it done tommorow with no problems! I cant wait pretty excited.
Tue Apr 03, 2012 8:02 pm
Got it all done tonight, can't wait to try it out Saturday with the new prop hopefully tear some shiii up!
Wed Apr 04, 2012 7:35 pm
