It is currently Mon Apr 06, 2026 2:04 pm
[ 9 posts ] |
low speed RPMs on 23 hp longtail
power731
What RPMs are yall running at idle on 23 longtail?
| Thu Apr 05, 2012 5:57 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
 Re: low speed RPMs on 23 hp longtail
I have mine set at 1050 on my 25.
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
| Thu Apr 05, 2012 6:04 pm |
power731
I cannt get mine below 1500 without losing top end 3600.
| Thu Apr 05, 2012 6:12 pm |
PaleoHuntr
Yep, that's the problem. Mine top out at 2852, which is fine with me as I like the low idle speeds.
| Thu Apr 05, 2012 6:16 pm |
daisy cutter
Joined: Wed Sep 28, 2011 12:24 am Posts: 297 Location: Hartselle, AL
mine idles at about 1200 out of the water and about 950-1050 in the water. top end is about 4030 out of water and 3740-3800 in the water. anything lower than 1200 out of water and it stalls when i drop the prop in the water
_________________ fiat justitia et pereat mundus 1642 WeldBilt Crawdad/ 23hp S.W.O.M.P viewtopic.php?f=18&t=27507 viewtopic.php?f=18&t=27513
| Thu Apr 05, 2012 6:25 pm |
power731
I like that RPm range. May have to do a little tinkerin with throttle
| Thu Apr 05, 2012 6:29 pm |
mudduck1448
Joined: Sat Sep 10, 2011 6:34 pm Posts: 90 Location: Four Oaks, NC
1100 idle and 4090 wot both in the water.
| Sun Apr 08, 2012 7:26 pm |
Buzz Killington
B. MacDonald
| Mon Apr 09, 2012 6:59 am |
power731
did my tinkerin today got 1200 low end and 3850 high end. think I can live with this. Had to cut jacket on cable and cut grove in throttle stop. Think I can get a little more on hoigh end if I do little more cuttin.
| Mon Apr 09, 2012 6:51 pm |
[ 9 posts ] |
