JSS3
Joined: Mon Mar 12, 2012 1:17 pm Posts: 40 Location: Lizella, Ga
 Auto Luber leaking around threads?
Everytime i run my motor it leaks around the threads of my auto luber where it is screwed into the shaft. It pushes out a good bit each run. I have tried locktite and teflon tape, and a combo of the two. Any sugestions on how to seal this up?
| Tue Apr 03, 2012 5:19 pm |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
 Re: Auto Luber leaking around threads?
You could always weld it...
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
| Tue Apr 03, 2012 5:22 pm |
JSS3
This is true...it damn sure wouldnt leak then, but this would make replacing it quite a challenge.
| Tue Apr 03, 2012 5:54 pm |
Randy S
Joined: Sun Oct 02, 2011 4:03 pm Posts: 313 Location: NELA
Is it leaking from where the luber screws into the shaft housing or between the plastic auto luber housing and threads? Could be that the plastic is detaching from the threaded piece or is cracked?
| Tue Apr 03, 2012 6:04 pm |
Otter1
Joined: Thu Jul 21, 2011 7:00 am Posts: 17 Location: NE Nebraska
Mine completly fell off the shaft. Where the plastic was bonded to the metal sort of crystalized and broke apart. I replaced it with a all metal unit except for the plastic cover. I got it from McMaster-Carr.
| Wed Apr 04, 2012 6:59 am |
JSS3
| Wed Apr 04, 2012 1:16 pm |
Randy S
Since you've tried teflon tape, I'd move on to pipe joint compound; it's thick enough to seal where tape won't, but I'm not sure how it'll hold up to the grease.
| Wed Apr 04, 2012 6:06 pm |
JSS3
Its worth a try...thanks!
| Wed Apr 04, 2012 6:10 pm |
CCC
Put alot of Teflon and put it on in the right direction.
| Thu Apr 05, 2012 6:55 am |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
take a 1/8 npt coupler, cut it in half then weld it over the wore out hole.
| Thu Apr 05, 2012 4:40 pm |
JSS3
| Thu Apr 05, 2012 7:33 pm |
JSS3
| Sun Apr 15, 2012 6:31 pm |
garjacker
yea mine looked the same way. i used this on my homebuild. I just got some marine epoxy and smoothed it up and painted,looks like a factory job. I am the king of negroflage....
| Sun Apr 15, 2012 8:07 pm |
Gondo
| Sun Apr 22, 2012 7:52 am |
JSS3
McMaster Carr---Part # 1303K14 would be the metal one.
| Sun Apr 22, 2012 8:09 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
_________________ so many rivers, so little time
| Sun Apr 22, 2012 2:03 pm |
