It is currently Thu Apr 02, 2026 10:09 pm
[ 6 posts ] |
scotto
 Need help
I want to get a new boat and motor to run shallow rocky streams. I am thinking of a 14' Jon with a mud buddy mini 14., or would a longtail be the best for this situation? Any help will be much apreciated.
| Wed Apr 25, 2012 11:16 am |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
 Re: Need help
I've never run in such "aqua-terrain" but I've read where conventional jet drive outboards are used. Before investing, see if the nearest marine or mud motor dealer will let you take a test drive or offer suggestions. Although they make prop protection plates and such for both surface drive and longtail motors, there are similar devices for conventional outboards. The reason I say this is you may realize you don't need a mud motor of either type if you don't have much mud or vegetation, you describe shallow water and rocks and if this is mostly clean water a regular outboard may manage. Take your time and shop around, get all the information you can, and again, test drive it!
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Wed Apr 25, 2012 2:02 pm |
blackduck
Joined: Mon Nov 14, 2011 4:07 pm Posts: 145 Location: Nevada
 Re: Need help
I ran a 16' smoker craft fishing jet boat on the Sac River in 6"in of water. It had a 4.3L vortec. I would say a jet on an outboard would be best. It doesn't hang down as far as a standard prop outboard. You will loose a couple hp's with a jet but you wont be bouncing of the bottom like a longtail or a proped outboard would.
| Wed Apr 25, 2012 6:12 pm |
montrose trapper
 Re: Need help
As mentioned before if the water is clear of weeds and mud run a standard short shaft outboard. I have a 1436 that I used to run the flint river around me with and all I did was take a pitch fork head and bend where it mounted to the handle. Then I made a mount that bolted to the wings above the prop and mounted it so the tines of the fork stuck down below the skeg. Run your motor on tilt and haul balls if your mount and welds are good she just kicks right up outta the water when you hit a rock or log.
| Wed Apr 25, 2012 8:44 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
 Re: Need help
^^ good idea there! I ran my boat like this for a while, minus the pitchfork, just kept the outboard loose and it would kick up without damage to the prop. I started running a lot of muddy bottoms and chewing up impellers so I got a longtail.
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
| Wed Apr 25, 2012 8:53 pm |
montrose trapper
 Re: Need help
I wish I woulda never sold that 15. We'd use it walleye fishing in the spring and it moved 3 guys upstream fast. Oh well I spend more time in a boat in the fall than in the spring or summer so the home build longtail won the prize[url][url][/url][/url]
| Wed Apr 25, 2012 9:22 pm |
[ 6 posts ] |
