It is currently Mon Apr 06, 2026 2:35 am
Reply to topic  [ 8 posts ]
 Another cav plate topic!!
Post Another cav plate topic!!
when i start moving in my boat my motor is easy to handle/ control. As i speed up, and get close to the top speed my motor wants to climb to the clouds. In other post i have seen, i beleive i need to bend the cav plate away from the prop, or towards the prop? My plate is about an inch from the prop. Not sure if its also the fact that i think that my motor is big but i will post that in another topic toimorrow with pictures. thanks for the help
Fri May 25, 2012 7:10 pm
Post Re: Another cav plate topic!!
'motor climbs to the clouds' doesn't tell me anything. is the prop trying to surface or dig deeper in the water?
surfacing, bend plate edge away from the prop. digging, bend toward the prop.
Fri May 25, 2012 7:58 pm
B. MacDonald
Fri May 25, 2012 8:24 pm
Yes it wants to surface. It takes all my arm has to keep it in the water. Roughly how much should I adjust it. Just do a inch at a time or do more then that.
Fri May 25, 2012 10:42 pm
no where near an inch, it won't take much at all. just bend a small spot in the middle of the plate a 1/4 inch or so, if that doesn't do it, bend the plate on both sides of the previous bend. work your way out to the edge till it rides under the surface. easiest way is with an 18 inch pipe wrench or large crescent wrench.
Fri May 25, 2012 10:50 pm
thanks indawoods. one more thing tho. there is a peice of 1''x1/4'' flat bar welded on top in the center the full legnth of the cav plate. should i make a notch in the flat bar and bend it? ill post pics tomorrow so ppl can see what i talking about
Fri May 25, 2012 11:06 pm
bending up on the sides should be enough, it usually doesn't take much. you'll learn that how you load the boat will effect it as well, a load towards the front will pick the back end of the boat up and may cause it to surface, while a heavy load causes the motor to dig deeper. trial and error.
only bend the trailing edge, the last 1/2 inch or so.
Sat May 26, 2012 2:13 pm
Thanks indawoods. thats the only part i bent up. was going to see if it made a difference today after i bent it i was just checking everything over and starting the motor.......you know just to make sure it will start b4 i get to the launch and my boat decided to be ignorant and not run so now i have to go thru the carburater and find out why im not getting gas. if its not one thing its another
Sun May 27, 2012 9:57 pm
