It is currently Fri Apr 10, 2026 7:21 am
[ 4 posts ] |
duckdog34
Joined: Wed Dec 01, 2010 8:25 pm Posts: 22 Location: Covington, La
 Honda 20 not charging
I have a 20 hp Honda gdlt I can't seem to figure out why it it not charging the battery when running. The only wire not hooked up is wire with blue stripe coming from rectifier when using volt meter and test that wire I'm not seeing a change in volts. Any help would be great
_________________ 14x48 Grizzly Tracker 27 Prodrive
| Sun Jun 03, 2012 8:22 pm |
139sst
 Re: Honda 20 not charging
Sometimes the stater goes out. I think its the magnets on the flywheel.happens on my lawn mower.
| Mon Jun 04, 2012 4:03 pm |
duckdog34
What do you have to do to replace?
| Mon Jun 04, 2012 6:54 pm |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
I believe you can check the ac voltage coming from the stator/magnet into the rectifier it'll be ac voltage Then should have dc out of the rectifier around 13.5-14 dc
Btw you have to pull the covers some of the fuel system then "pull" the flywheel to get to the stator and magnets
| Mon Jun 04, 2012 7:05 pm |
[ 4 posts ] |
