LONG TAIL TROLLING MOTOR CONVERSION
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=30599
Author:  Loutre Bottom Boy [ Sun Jul 08, 2012 11:47 pm ]
Post subject:  LONG TAIL TROLLING MOTOR CONVERSION
Hey guys I was wonderin if anybody has ever rerouted or customized the shaft of a Trollin motor to resemble a long tail? If so what is the new shaft made out of? Thanks
Author:  benellibrian [ Sun Jul 08, 2012 11:55 pm ]
Post subject:  Re: LONG TAIL TROLLING MOTOR CONVERSION
WHY :?: :?: :!:
Author:  Woodiebuster [ Mon Jul 09, 2012 8:20 am ]
I thought about it a couple years back, then realized I was wasting my time. There just isnt enough power in a trolling motor to do what it needs to do.
Something I have always wanted to try though is a LT with a golf cart engine on it.
Author:  Will [ Mon Jul 09, 2012 9:44 am ]
Author:  Loutre Bottom Boy [ Mon Jul 09, 2012 11:57 am ]
Well I've got an Otter 2000 that I'm putting it on and it's a 40lb thrust so it's Gunna have enough power for that just nothing bigger
Author:  Woodiebuster [ Mon Jul 09, 2012 5:29 pm ]
Are you Loutre Bottom Boy as in Bayou De Loutre up above Farmerville?
My first boat was a 9' pond prowler alot like an otter, it had a 30lb Minn Kota on it.
I used to hunt alot of small loggy creeks and grassy sloughs... I took the all the tilt stuff out of it where it could free float up and down over logs and stuff. Raise the prop up to where it breaks the surface of the water and it will pretty well stay weedless.
You can run in as much water as the boat drafts like this, maybe a lil less if the mud is soft. But it will never compare to a real MM.
Author:  Loutre Bottom Boy [ Mon Jul 09, 2012 7:17 pm ]
Sure am.
And I'll try that b4 I tear into it. The only bad thing is tryin to control it from that far up the boat since the transom is so far behind the seat
Author:  Woodiebuster [ Mon Jul 09, 2012 8:17 pm ]
I did a tiller extension with a peice of 1" PVC pipe if I remeber correctly.
take the rubber off the handle and cut a couple of slits in the pipe, should slide right up there snug.
Author:  Loutre Bottom Boy [ Mon Jul 09, 2012 10:15 pm ]
Thanks bud I appreciate the tips. So u from Choudrant ?
Author:  Woodiebuster [ Mon Jul 09, 2012 10:17 pm ]
Yep, several members from around here.
Author:  Loutre Bottom Boy [ Tue Jul 10, 2012 5:51 am ]
That's cool. Yea I live over round Hatley Lake on the Loutre
