It is currently Wed Apr 08, 2026 8:27 pm
Reply to topic  [ 10 posts ]
 mudbuddy unstable
Post mudbuddy unstable
i have a 14ft mudbuddy with a 25hp kohler engine on it with the longtail drive i was wondering if anyone could give me a tip on how to make it more stable it wants to flip way to easy i have the 6 gallon gas tank and battry in back with me im 210 pounds i know that dont help. if i move that other stuff forward would that do anything for me. i made a performance pod but it slows me down ALOT so i might take it off. what would you guys try out thanks for any help
Wed Jul 11, 2012 11:49 am
Post Re: mudbuddy unstable
buy a bigger boat
Wed Jul 11, 2012 11:54 am
New boat or start datin a fat chick and have her ride in the front all the time :lol:
pd36 fpr 1754 cc rig
Wed Jul 11, 2012 12:02 pm
swampbilly
you should get paid for advice like that. I suggest you run for office, or get a day time talk show.
Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
Wed Jul 11, 2012 1:27 pm
try and re locate a lot of your stuff.
Battery/gas tank/cooler etc.... Move it forward
Try and find that good balance point on your boat at WOT by yourself and - it's kind of a trial by fire.
Good luck
B. MacDonald
Wed Jul 11, 2012 6:24 pm
The first thing you better do is get a life jacket and then start moving stuff around.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Thu Jul 12, 2012 9:25 pm
more info needed. like u said its a 14' boat! how wide is i? when u put the pods on did u make sure the furthest part away from the boat was up about a 1/2"? need more info?
Sat Jul 14, 2012 1:49 pm
i run a 23 lt on a 1448 i have no probs... how wide is your boat also weight divided out throughout the boat on a longtail is a must... i weigh 225 and push my rig at 20mph empty try putting the battery up front and other gear
Sun Jul 15, 2012 8:21 pm
i moved my battry into my dry box an my gas tank up to the front now i just need to test it. yes i made sure the pods tilted up a little it might be a little more then half inch. this is my first year with a mud buddy is it suppossed to be so hard to turn and keep my prop down when running full throttle
Wed Jul 18, 2012 6:25 pm
TRY ADJUSTING THE CAV PLATE....IF NOT MAKE SURE YOU GOT THE CORRECT HEIGHT ON THE TRANSOM
Wed Jul 18, 2012 9:52 pm
