It is currently Sun Apr 12, 2026 10:50 pm
Reply to topic  [ 18 posts ]
 Shaft Prices
Post Shaft Prices
What seems to be a typical price for a new shaft? I have a bog hog lt. Their website sells shafts for $120. Using the search function on here, I saw around $100 mentioned. I called a local machine shop to get a quote for machining my own shaft. They said around 3 hours to set up the lathe and mill to cut the threads and keyway at $65/hr rate. This makes the bh shaft seem worth it but 3 hours seems like a long time to cut threads and a keyway? Is this on par or should I keep looking? I had a hard time just finding a shop that would do it/offer a quote. Most shops around here seem to only do production work and no custom stuff.
As a comparision, I found that bt sells their 71 inch shaft for $88.
So many projects piling up now....It's just time and money, both of which I seem to be running out of :lol:
Mon May 21, 2012 7:59 pm
Post Shaft Prices
Go devil shafts are $62 if I remember correctly.
1648 weld bilt being followed by a 35 gtr
Mon May 21, 2012 8:08 pm
Post Re: Shaft Prices
B. MacDonald
Tue May 22, 2012 7:57 am
Tue May 22, 2012 6:16 pm
i just bought a shaft from go devil last week and it ran me 80$ plus shipping
Tue May 22, 2012 8:00 pm
Post Shaft Prices
B. MacDonald
Wed May 23, 2012 5:15 am
Hold up you said you have a "no name" longtail? I read you have a boghog, which is a name brand, last time I checked. So stop being a dumbass or a cheap ass and just buy the boghog replacement shaft, PLEASE for the love of GOD do it!!!!!!!!!
1542 FLATBOTTOM WITH 24 HONDA MUD BUDDY MINI TURNING A 12" GDSD PROP/17 FT XPRESS CENTER CONSOLE WITH 90 MARINER
Wed May 23, 2012 7:48 am
Profile YIM
If you would read a little before you opened that cocksucker of yours you would know Bog Hog went under.
Who is the dumbass now? :roll:
Wed May 23, 2012 11:22 am
I had to pay $120 plus shipping($138 delivered to door) from mudbuddy.
Wed May 23, 2012 5:32 pm
Wed May 23, 2012 5:46 pm
Wed May 23, 2012 5:50 pm
my time is valuable, so all the time you wasting being a cheap azz, you could have been back and running already. To each his own, but i bet a bog hog shaft would be easier , simple fact it is made for the frame. And by the way Woodie, you been pretty stupid lately, maybe you need some pussy idk. Go research Bog Hog more Woodie and you will find they still are very much in business. These statements and words are not intentional meant to hurt or offend anyone, so please read with warning. Thanks, Bobby
Thu May 24, 2012 5:58 am
Profile YIM
Your time can't be that valuable if you come on this site, read posts, and then make useless comments.
I understand that buying a shaft from bog hog would be the easiest route, but that wasn't my question. I wanted to know how much people pay for a shaft from other companies or from local machinists. My time is valuable, but so is money when you don't have a lot to throw around. This is a project that I am in no hurry with. I have until duck season to work all the kinks out.
I am just tossing ideas out there for some input. I don't mind taking my time and saving some money on this project.
Thu May 24, 2012 7:31 pm
What material is the shaft made out of? Don't want it to soft get me the material I will cut it for you buddy
Thu May 24, 2012 8:07 pm
Just ordered shafts from local metal supplier, $26 a piece. Local machine shop is keying/ threading for $175 for 4 shafts.....
If I can't Break it, it can't be Broke.............................
Fri May 25, 2012 6:49 pm
What type metal? Is it a hardened steel or plain cold roll?
Shoot 1st ask later
14' leaker w/ 20hplt
Shootin time Teal Season 2010 http://xrl.in/64aw #countdown
Thu Jul 26, 2012 8:58 am
I just bought 2 and had them machine for key way and threaded for $75
1748 WC Custom 27 mini
Thu Jul 26, 2012 1:20 pm
For small Hp, 10 or less, Cold rolled 1018 will probably suffice. Anything bigger, I like to use 4140 pre hard turned ground and polished or 17-4 H1150 . The 17-4 is usually slightly oversized for bearings, so you do have to do some work with emery cloth or take a light pass on the lathe to get a good transitional fit.
Fri Jul 27, 2012 12:05 pm
