It is currently Mon Apr 06, 2026 1:33 am
[ 5 posts ] |
KaCajun Boy
Joined: Tue Nov 01, 2011 2:43 am Posts: 179 Location: SELA
 Blew 2 lower seals!!
So I changed my upper and lower seals and bottom bushing, went for a test run came home and I had blew my 2 lower seals. Never had this happen before. The shaft is stright, they had the recommended space in the bushing and I didn't over grease or hit anything. How can I prevent this or what went wrong?
_________________ 23hp GDLT on 16x38 GD boat When up to your nose in shit, don't open your mouth.
| Fri Aug 03, 2012 5:14 am |
Rem man
Joined: Sun Sep 19, 2010 7:49 pm Posts: 120 Location: Coastal GA
 Re: Blew 2 lower seals!!
Did you wrap the threads on the shaft before you put the seals on?
| Fri Aug 03, 2012 2:06 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
Grit and sand can get under the seals and actually wear the shaft down to where you dont have enough contact surface. check the shaft o.d.
| Fri Aug 03, 2012 8:16 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
If the lower bushing has the spiral groove on the inside the grease return slot on the out side of the bushing may be plugged. If it is plugged the most common cause is too much silicone sealant or a stray piece of thread tape. Plug the lube fitting with a 1/8 pipe plug and see if grease can be forced out the return slot.
_________________ so many rivers, so little time
| Sat Aug 04, 2012 2:13 am |
KaCajun Boy
i replaced the seals everything looked ok will run it tomorrow.
| Tue Aug 07, 2012 4:53 pm |
[ 5 posts ] |
