It is currently Mon Apr 06, 2026 2:46 pm
[ 7 posts ] |
Help my motor wont turn the drive shaft
Pimptibbs
Hey guys this is my first mud motor and I made the mistake of buying it without the shaft put in and the u-joint. Motor runs great its a 7hp, starts on first pull every time and runs great for as long as I want. BUT, I put in the shaft and u-joint and its crazy hard to pull and I cant even get the motor to run. I take off the u-joint and the motor fires right up. Its a 6' long tail frame. Im stumped and dont know what to do. Any help or ideas to try are appreciated! Thanks!
| Tue Aug 07, 2012 12:45 pm |
Woodiebuster
 Re: Help my motor wont turn the drive shaft
Sounds like its not aligned properly.
| Tue Aug 07, 2012 1:11 pm |
Pimptibbs
The tail with the motor? So maybe cut the welds and decrease the degree of angle till it runs right and re-weld?
| Tue Aug 07, 2012 1:21 pm |
Woodiebuster
No, your problem sounds like the motor is mounted crooked either left or right of being straight with the shaft... not up/down.
Make double sure everything is square, just a little bit off will put a bind on the U-Joint like you are saying.
| Tue Aug 07, 2012 1:46 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
what kind of frame? friend made an adapter for his 16hp mud buddy frame and put a 6.5hp on it and it wouldnt turn over. If its a home build then it def could be an alighnment issue as stated above,too much metal, or too much angle on the ujoint .
| Tue Aug 07, 2012 5:47 pm |
Cajunwannabe
Joined: Wed Jan 28, 2009 3:40 pm Posts: 188 Location: Wishing I was in SE La.
U joint too deep on motor shaft OR Shaft too deep on U joint OR BOTH.
Dry fit u joint and shaft and manually turn the prop to see how hard it is to turn until you can turn it pretty easily. When you think you have it right, TIGHTEN IT UP, then run it but check for heat in case it's still binding.
You have to find the "sweet spot". Don't ever remove the U joint or shaft without marking where they are currently set.
If none of this works, fella sold you a bill of goods.
| Tue Aug 07, 2012 8:26 pm |
zrdc28
Take the spark plug out of the motor and move everything around until you can turn it freely from the prop and then lock it down.
| Thu Aug 23, 2012 6:03 pm |
[ 7 posts ] |
