| Need new U-joint http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=32033 |
| Author: | SouthernWake [ Mon Sep 03, 2012 9:30 am ] |
| Post subject: | Need new U-joint |
Where would be the best place to buy a replacement universal both local and online? I had mine shred the key and strip out the knotch in it. This is a homebuilt so no manufactureer to call on it. Thanks |
| Author: | brianb [ Mon Sep 03, 2012 11:27 am ] |
| Post subject: | Re: Need new U-joint |
try driveshaftparts.com or tractor supply, just check the rpm ratings |
| Author: | Docott [ Mon Sep 03, 2012 12:18 pm ] |
X2 tractor supply |
| Author: | garjacker [ Mon Sep 03, 2012 4:39 pm ] |
napa |
| Author: | SouthernWake [ Tue Sep 04, 2012 8:49 am ] |
Thanks everyone, I took the old one off this morning and noticed that it stripped out the key groove on the shaft as well... I was thinking about drilling a hole through the universal and shaft and inserting a pin to hold it all together instead of using the key as this is the second time I've had one strip out. What do you guys think of this? |
| Author: | Pumpgunner [ Thu Sep 06, 2012 12:03 pm ] |
Everything I've heard says don't drill through the shaft, it will create a serious weak spot. As much as it sucks, you might have to replace your shaft. |
| Author: | Buzz Killington [ Thu Sep 06, 2012 7:13 pm ] |
