It is currently Mon Apr 06, 2026 1:02 pm
Reply to topic  [ 7 posts ]
 Need new U-joint
Post Need new U-joint
Where would be the best place to buy a replacement universal both local and online? I had mine shred the key and strip out the knotch in it. This is a homebuilt so no manufactureer to call on it. Thanks
Mon Sep 03, 2012 9:30 am
Post Re: Need new U-joint
try driveshaftparts.com
or tractor supply, just check the rpm ratings
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Mon Sep 03, 2012 11:27 am
X2 tractor supply
Mon Sep 03, 2012 12:18 pm
napa
Mon Sep 03, 2012 4:39 pm
Thanks everyone, I took the old one off this morning and noticed that it stripped out the key groove on the shaft as well... I was thinking about drilling a hole through the universal and shaft and inserting a pin to hold it all together instead of using the key as this is the second time I've had one strip out. What do you guys think of this?
Tue Sep 04, 2012 8:49 am
Everything I've heard says don't drill through the shaft, it will create a serious weak spot. As much as it sucks, you might have to replace your shaft.
Thu Sep 06, 2012 12:03 pm
B. MacDonald
Thu Sep 06, 2012 7:13 pm
