| BENT SHAFT AGAIN http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=32401 |
| Author: | power731 [ Sat Sep 15, 2012 6:20 pm ] |
| Post subject: | BENT SHAFT AGAIN |
Started with cold roll steel, bent it, made one out stainless bent it today. Have 22 hp engine with 3/4 shaft and bearings top and bottom. Have brass washer in front of prop and nylon behind prop. Was running half throttle when I hit log. Any suggestions thanks |
| Author: | 270Handiman [ Sat Sep 15, 2012 6:46 pm ] |
| Post subject: | Re: BENT SHAFT AGAIN |
Pics needed. Sounds like you need to either beef up the structure or add support to the shaft. |
| Author: | power731 [ Sat Sep 15, 2012 7:06 pm ] |
The outer shaft is 1/4 inch steel tubing. I keep bending the 3/4 inch prop shaft. |
| Author: | power731 [ Sat Sep 15, 2012 7:16 pm ] |
Picture of motor. |
| Author: | brianb [ Sat Sep 15, 2012 7:25 pm ] |
So it is bending at the prop? |
| Author: | waterfowl1 [ Sat Sep 15, 2012 7:27 pm ] |
where is it bending? shorten the gap between yur prop and shaft housing. |
| Author: | power731 [ Sat Sep 15, 2012 7:32 pm ] |
I have a 3/4 inch nut, a 1/16 inch brass washer and a 1/16 inch trush washer between prop and bearing housing. |
| Author: | wm [ Sat Sep 15, 2012 7:46 pm ] |
| Author: | power731 [ Sat Sep 15, 2012 7:55 pm ] |
what size and motor have you got? |
| Author: | wm [ Sat Sep 15, 2012 8:13 pm ] |
35 |
| Author: | Buzz Killington [ Sun Sep 16, 2012 4:52 am ] |
Stop hitting logs? Put 1 nut and 1 washer above the prop to the bearing. Keep the distance from that nut to the bearing housing less than an inch distance. Should do the trick. |
