ge1111
u joint replacement
i need to find out where to find a u joint for my old long tail im not sure who manufactured it no tags, markings etc i need a new u joint bad and the local go devil rep is no help since i cant prove it is a go devil product Thanks gregg
Fri Jul 17, 2009 11:09 am |
kibb
Re: u joint replacement
Where ya from? If you're from the Lafayette area try Voorhies in New Iberia or try a Tractor Supply Warehouse.
Fri Jul 17, 2009 11:25 am |
ge1111
Im from Orange Texas about 100mi east houston right on tex/la line on ih 10 i'll try tractor supply co thanks gregg
Fri Jul 17, 2009 12:50 pm |
darrel from meraux
Joined: Wed Feb 18, 2009 9:31 pm Posts: 584 Location: Meraux, LA
look to see if theyrs a twist in the frame by the motor then it's a godevil. if not i have a ton of frame numbers you could use to get yourself a u joint direct from godevil
_________________ 17x54 custom CC with stage 3 GTR.
Fri Jul 17, 2009 10:04 pm |
ge1111
thanks there is no twist in frame i am going to take some pix tomorrow and post them for observation if i can. it just seems there should be able to find one that works in a driveline supplier or something thanks for all your help. gregg
Fri Jul 17, 2009 10:24 pm |
Da-Cajun-Angla
i bought 1 yesterday 4 14 bucks plus tax at o'reillys.
_________________ cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Mon Jul 27, 2009 1:00 pm |
Da-Cajun-Angla
its not complicated...place 1 side in the vice,tap the retaining rings out, grab a hammer and a railroad spike or something, and tap on top and bottom of each 1. i had to really put some ass into a few of them to get em out. take it to o'reilys, and they will match it out. the next size up is so much bigger, its not hard to figure out which 1 u need.
Mon Aug 10, 2009 2:04 pm |
