It is currently Sun Apr 05, 2026 7:36 pm
Reply to topic  [ 4 posts ]
 Longtail Shaft question
Post Longtail Shaft question
Is it normal for the grease to come out at the bearing where the motor is connected to the shaft? It seems like everytime i drive the boat and come back to the landing and check where the camo covers the joint there, theres always grease leaking there. is that normal? It looks like the grease is spitting out when its turning because its all over the camo sheet cover.
Tue Sep 25, 2012 7:24 am
Post Re: Longtail Shaft question
Alot of grease or a little? We usually see some grease but not much, almost like some residual left on the zerk from greasing the
u-joint...
1436 Lowe
Tue Sep 25, 2012 9:37 am
Mine always has a good size glob sitting in there and its just got bigger over the years. I never pay it much mind just pump a couple shots of grease in their every couple of trips.
1748 WC Custom 27 mini
Tue Sep 25, 2012 4:39 pm
i always have some grease flung around but its never a large amount,my comes from greasing the u-joint.if you have a large amount check your seals.
Tue Sep 25, 2012 9:32 pm
