| Replacing a GoDevil shaft http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=32873 |
| Author: | audu1985 [ Tue Oct 02, 2012 6:10 pm ] |
| Post subject: | Replacing a GoDevil shaft |
I have a 2000 kohler decided to replace the shaft. Ive taken the prop off and the nut assembly off unscrewed the set bolts on the lower yoke. Now how do i get the upper and lower housing assemblies off to install the new top bearing and replace the bushings and do i just beat the shit out of the prop till the shaft starts the move and then take the shaft key out. Pictures or videos would be helpful because i cant find anything useful on the internet. |
| Author: | bbb [ Wed Oct 03, 2012 10:52 am ] |
| Post subject: | Re: Replacing a GoDevil shaft |
That would be about right. Hit the backside of the prop and the shaft will eventually work its way out of the yoke. Might want to try to put a flat head screwdriver in the slot of the yoke to loosen it up some. The new shaft goes in the same way, beat it. |
| Author: | da go get'er [ Wed Oct 03, 2012 10:57 am ] |
a slide hammer is the correct application for this. |
| Author: | stualaska [ Wed Oct 03, 2012 2:50 pm ] |
Please download the service manual from the Godevil website. http://www.godevil.com/documents/Go-Dev ... Manual.pdf |
| Author: | bbb [ Wed Oct 03, 2012 3:04 pm ] |
| Author: | david95 [ Wed Oct 03, 2012 6:02 pm ] |
Make sure to replace upper an lower seals, I did this an only replaced lower and it wouldn't keep grease for no longer than 5 minutes in the autoluber. |
