It is currently Fri Apr 03, 2026 12:33 am
Reply to topic  [ 3 posts ]
 Thoughts?
Post Thoughts?
16 Vanguard GDLT rpms at idle 1200ish and wot 3900, both out of water. I plan on putting it in the water tomoro and wanted to see if that was average.
Sun Oct 07, 2012 2:44 pm
Post Re: Thoughts?
My 16 idles out of water at 950 and WOT out of water is 4250. In water 3250.
Sun Oct 07, 2012 8:58 pm
Post Re: Thoughts?
You should be able to idle it down as low as it will keep running when you submerge the prop and turn the OOW up to a little over 4000 if you want. Where it is set now should be just fine though.
Sun Oct 07, 2012 9:00 pm
