It is currently Fri Apr 03, 2026 12:30 am
Reply to topic  [ 12 posts ]
 HUGE PROBLEM with shaft and engine
Post HUGE PROBLEM with shaft and engine
Ok I am going this weekend to buy a predator 420cc at harbor freight because they having a parking lot sale and the motors are $100 or more off...well the output shaft on the motor is 1" and my inner shaft for my longtail is 3/4"... How do I fix this??????
Do not let a flattering woman coax and wheedle you and deceive you; she is after your barn.
Thu Oct 11, 2012 9:55 pm
Post Re: HUGE PROBLEM with shaft and engine
Get a u joint that is 1 inch on one side and 3/4 on the other. I'm sure they make something like that
Thu Oct 11, 2012 10:05 pm
1436 Lowe
Thu Oct 11, 2012 10:27 pm
You can certainly get a u joint that works. You can buy the joint in three separate pieces. Small shaft end, big shaft end, and spider (center part)
Thu Oct 11, 2012 10:28 pm
Thu Oct 11, 2012 10:30 pm
Dam, and I clicked on this hoping for something major....
Team Arc Angel Bowfishing
Thu Oct 11, 2012 11:22 pm
My bad guys! I read on another forum that I was going to have to put a clutch on it and cost around 400$. I didn't know you could mix yoke sizes on the u joints!
Fri Oct 12, 2012 6:30 am
Fri Oct 12, 2012 6:34 am
Why is the predator 420cc 13 horses and the Duromax 420cc 16 horses? Is there a difference in the carb or exhaust?
Fri Oct 12, 2012 8:41 pm
Squirrel
Fri Oct 12, 2012 11:20 pm
I thought they used hamsters... ;-)
Sat Oct 13, 2012 7:04 pm
You cant mix yoke sizes, just what shaft the yoke is built to fit. They are all going to be 1000 series yokes just built to fit either a 3/4 or 1" shaft.
Mon Oct 15, 2012 7:28 am
