| Start over maybe http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=33476 |
| Author: | Joel907 [ Sat Oct 20, 2012 10:07 pm ] |
| Post subject: | Start over maybe |
Ok this is my first one I don't know what I'm doing I found a 6 foot pipe that is used for making the roll cage In dragsters it not that thick of walled. Will not hold a set screw But will hold the zerks. So I welded on some nuts to hold set screws. It just going to be a 7hp longtail should I use the tube or Find somthing thicker. How tuff should the outer house be. |
| Author: | autogateman [ Sat Oct 20, 2012 10:12 pm ] |
| Post subject: | Re: Start over maybe |
thats for the shaft housing?? i definitely would go thicker. even if you only have 7hp, the impact is still high when you hit something. just my .02 |
| Author: | brianb [ Sat Oct 20, 2012 10:16 pm ] |
Best to use dom tube |
| Author: | Joel907 [ Sun Oct 21, 2012 7:01 am ] |
It still DOM tube I fig you SS shaft would take most Of the force if you hit somthing. No ? |
| Author: | ironman_gq [ Mon Oct 22, 2012 10:26 am ] |
the shaft transfers all of the upward shock through the bushings and into the tube, not to mention steering forces and some of the thrust load. I wouldnt go thin on the shaft tube, it will probably bend |
