It is currently Mon Apr 06, 2026 1:02 pm
[ 3 posts ] |
db5
Joined: Wed Feb 22, 2012 11:43 pm Posts: 28 Location: metairie, LA
 bushings and seals
well i changed my bushings and seals on my longtail...dont know when or if the previous owner did but i only put about 10 hours on it started pouring grease from the front seal...replced the bushing and seals and the manual says after running the motor 45 seconds at idle you should be able to toach it without burning yourself...well after about 30 seconds it was scorching...the temperature gun was reading about 180 - 200 degrees at the front of the shaft and about 80 in the middle and back...anyone know what i did wrong and can be causing this? also does anyone know about what temoerature it should be? thanks!
| Mon Nov 05, 2012 9:53 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: bushings and seals
What brand of longtail is this? Got a pressure cup? Definitely a lack of grease....
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Mon Nov 05, 2012 10:45 pm |
db5
Its a go devil...yes it has the lubricator cup...I'm going to ft a new one today because I cracked mine yesterday
| Tue Nov 06, 2012 6:47 am |
[ 3 posts ] |
